engine power low
50,000 MILES • 2WD • MANUAL
BLICHUNGU
my engine is ck 4, it has lost its power and seems to jerk when driving, it is not picking fast as it normally did. i have changed the plugs and also the lead wires but it only improved a bit. what can the problem be?
Aug 29, 2017 at 9:39 PM
  • 55,710 POSTS
This sound like you may have a plugged exhaust system which restricts the flow causing the low power as you described. Here are a few guides that will help us get the problem fixed:
https://www.2carpros.com/articles/how-to-test-a-catalytic-converter
and
https://www.2carpros.com/articles/engine-has-low-power-output
and we should rear the codes to see if there are any.
Cheers, Ken
Aug 30, 2017 at 10:37 AM
