Engine overheats at idle or stop and go
70,000 MILES • 6.7L • V8 • RWD • AUTOMATIC
W94831254
  • 5 POSTS
My car overheats only when stopped or a lot of slow stop and go traffic.
Aug 20, 2017 at 9:29 PM
  • 55,834 POSTS
Does the engine have a fan shroud? Can you send me a picture of the fan set up?
Cheers, Ken
Aug 21, 2017 at 11:05 AM
W94831254
  • 5 POSTS
Yes it has a fan shroud. Aluminum radiator, five blade fan, with a thermal fan clutch. Fan Is four inches from radiator, and is out side the shroud 1/2".
Additionally, I had a 160' thermostat and resently changed it to a 195'.
Engine Is a 409ci with 475hp, bored .030 and a bigger cam. Aluminum heads, 2-4s.
Car hold temperature fine traveling down the road it is the long idling time that it heats up. Mainly at stop lights in a row and traffic.
Aug 21, 2017 at 10:10 PM
W94831254
  • 5 POSTS
I purchased the car one year ago, guy I purchased it from did built and installed to 409 engine in 2012. He was very meticulous and did not cut corners that I can see. He did not drive the car much, so there is less than 1,000 miles on it.
Aug 21, 2017 at 10:14 PM
  • 55,834 POSTS
It looks clean. when the car is heating up can you hear the clutch fan engage? It will roar when it starts to lock up. If not I would get a new fan clutch (GM) from rock auto and install it.
It is a fan problem or it would overheat when driving.
Cheers, Ken
Aug 22, 2017 at 3:59 AM
W94831254
  • 5 POSTS
Okay thank you. I will try that soon.
Aug 22, 2017 at 4:21 AM
W94831254
  • 5 POSTS
Clutch fan is not very old or used much. They go bad that fast or from lack of use?
Aug 22, 2017 at 4:22 AM
  • 55,834 POSTS
They can be just off, get a GM or ac delco from rock auto should do the trick.
Aug 22, 2017 at 3:39 PM
