My engine overheats, and it’s bubbling in the coolant tank
197,200 MILES
BRIEE RAY
My engine overheats, and it’s bubbling in the coolant tank. I know that those are signs of a blown head gasket but I don’t experience unexpected coolant loss, I know my coolant is leaking, white smoke hasn’t come out the exhaust pipe, and I don’t have any milky coat on my oil cap. I was wondering if there could be any other reason why my engine overheats beside head blowing gasket ?
Jul 30, 2021 at 7:09 AM
SQM
  • 6,383 POSTS
There are several factors that can contribute to a overheating engine.
You could have a stuck closed thermostat.
If the thermostat is stuck closed the temperature of the your upper and lower hose will be different.
https://www.2carpros.com/articles/how-an-engine-thermostat-works
Could be faulty / clogged radiator or hoses. The water pump could be bad and not circulating the coolant properly.
https://www.2carpros.com/articles/water-pump
It could also be that your radiator fan(s) are not operating as they should.
https://www.2carpros.com/articles/how-an-electric-cooling-fan-works
Is this something that just happened all of a sudden?
You might find this article helpful:
https://www.2carpros.com/articles/symptoms-of-an-overheating-engine
You can test to see if you have a blown head gasket. It is a very simple test.
It is a test tool you can get that checks for combustion gases in the coolant to determine if the head gasket is blown.
Here is how to do that test:
https://youtu.be/5zpNjYmmiYY
Please let me know little more info of what you find out.
Jul 30, 2021 at 7:20 AM
