Engine overheating with temp gauge rising and blinking... Large amounts of coolant leaking...
124 MILES
NICKLEM1
I'm having overheating problems and coolant leaking issues in my 1985 Volkswagen 1.9L Transporter.. The temp gauge on the dashboard rises every time I start the engine.. only when I have been driving on the motorways does in stop blinking and the gauge goes down to normal temp... Once I stopped the car and shut the engine off, I noticed large amounts of coolant leaking from somewhere ( I couldn't locate the source ). It was at the back on the drivers side near the rear wheel.
Any ideas what is causing the overheating problems? Radiator, Thermostat, Radiator cap, Water Pump?
Any help would be appreciated.
Thanks,
Nick
May 18, 2013 at 12:46 AM
  • 31,937 POSTS
You w ho get a mechanic to do a cooling system pressure test to locate this leak, do it soon as if you keep loosing coolant you will damage the engine.
May 18, 2013 at 8:32 AM
  • 31,937 POSTS
You will have to get a mechanic to do a cooling system pressure test, if the leak is not located and rectified you may damage the engine.
May 18, 2013 at 8:34 AM
