Replaced thermostat, and valve cover gasket and plugs. And oil change. Car overheated after thermostat replacement, which it was doing before replacement. I had a scan done before the thermostat replacement I got a 217 reading (hot engine) and a P300 (random cylinder misfire)which was done on 12-30-17. The first scan gave a P301 (cylinder one misfire), a few weeks ago, now it's random. The coolant reservoir was at max line before driving and when stopped after about six to eight miles it was at minimum. At a loss of the issue, have not done a pressure test on the radiator. Hopefully someone who is near me has one to use, so any advice will help.Thanks!
David
David
Jan 1, 2018 at 3:25 AM
