Engine overheating
230,000 MILES • 1.8L • 4 CYL • 2WD • AUTOMATIC
MATRIXMAN83455
Replaced thermostat, and valve cover gasket and plugs. And oil change. Car overheated after thermostat replacement, which it was doing before replacement. I had a scan done before the thermostat replacement I got a 217 reading (hot engine) and a P300 (random cylinder misfire)which was done on 12-30-17. The first scan gave a P301 (cylinder one misfire), a few weeks ago, now it's random. The coolant reservoir was at max line before driving and when stopped after about six to eight miles it was at minimum. At a loss of the issue, have not done a pressure test on the radiator. Hopefully someone who is near me has one to use, so any advice will help.Thanks!
David
Jan 1, 2018 at 3:25 AM
  • 31,937 POSTS
You do need to get the pressure test done and also a head check. this is a simple and quick chemical test for exhaust gasses in the cooling system. If this is positive you will have a head problem to rectify.
Jan 1, 2018 at 4:21 PM
MATRIXMAN83455
Thanks, I am having it taken to my mechanic to check out. It did not take long to overheat yesterday around ten to fifteen minutes. So I will mention the pressure test for gasses, and hopefully it is not a serious head problem as in a cracked head/block. Thanks again for your help.
David
Jan 2, 2018 at 3:12 AM
  • 31,937 POSTS
Okay, let us know how you get on. good luck and thank you for using 2carpros.
Jan 2, 2018 at 4:25 AM
