Temperature hand rises while driving and back normal when car is parked
165,000 MILES • 4.2L • AUTOMATIC
RODB256
Never smokes under the hood as if it is running hot though. I have changed thermostat twice, temperature sensors also. The sensor on the passenger side of the car stopped the temperature hand from working completely. So I had to put the old one back in.
Dec 13, 2020 at 1:41 AM
  • 110,248 POSTS
If the engine boils over and it is happening when you are driving, I would check the radiator to see if it is plugged. You have already done the thermostat.
https://www.2carpros.com/articles/coolant-flush-and-refill-all-cars
Also, there could be an issue with a head gasket causing the issue. Take a look through this link and see if anything mirrors what you are experiencing:
Let me know if any of that helps and what you find.
Dec 13, 2020 at 1:35 PM
