Engine overheating
169,675 MILES • 6 CYL • AUTOMATIC
BLESSING EWOBOR
  • 753 POSTS
Hello, the vehicle's engine is overheating. I have checked the coolant level of the radiator, it is okay and the fan is not using power. What could be the cause?
Dec 6, 2020 at 10:49 AM
  • 110,248 POSTS
Do you mean the cooling fan isn't working? Does the vehicle overheat when you are driving at highway speeds or is it only when in stop and go traffic?
The most common cause of overheating is a stuck thermostat. Take a look through this link. It explains how one works.
https://www.2carpros.com/articles/how-an-engine-thermostat-works
To be honest, this is the first place I would start, replacing the thermostat. However, I would like to know the answers to the questions I asked above.
If, however, you want to just replace it, here is a link that shows in general how it is done:
Here are directions specific to your vehicle. The attached pic correlates with the directions.
________________________________
Hint: if the thermostat was not installed, cooling efficiency would be harmed. If the engine should tend to overheat, do not remove the thermostat.
1. Drain engine coolant
2. Remove v-bank cover
3. Disconnect radiator outlet, no.2 hose clamp or clip
Pic 1
4. Remove water inlet w/thermostat
a. Remove the 3 nuts, water inlet with thermostat and gasket.
5. Install water inlet with thermostat
a. Install a new gasket to the water inlet with thermostat.
b. Install the water inlet w/ thermostat with the 3 nuts.
torque: 9.0 nm (92 kgf-cm, 80 inch lbs.)
6. Connect radiator outlet, no.2 hose clamp or clip
7. Add engine coolant
8. Check for engine coolant leaks
9. Install v-bank cover
a. Install the V-bank cover with the 2 nuts.
Torque: 7.5 Nm (76 kgf-cm, 66 inch lbs.)
Dec 6, 2020 at 1:18 PM
BLESSING EWOBOR
  • 753 POSTS
It seems that the cooling fan is working because it is attached to one of the engine pulley directly and not using electrical components. The vehicle overheat on highway speeds.
Dec 7, 2020 at 7:43 AM
  • 110,248 POSTS
Okay, then the first thing I would recommend is replacing the thermostat. I asked that question because at highway speeds, the airflow doesn't require the fan to do anything. Since it overheats when moving, I would replace the thermostat. The is the cheapest thing to try and the most likely problem.
Let me know if I can help or if you have other questions.
Dec 7, 2020 at 10:47 AM
BLESSING EWOBOR
  • 753 POSTS
Dec 10, 2020 at 8:41 AM
  • 110,248 POSTS
You are very welcome. Let me know if you have other questions or need help.
Dec 10, 2020 at 12:54 PM
