engine overheating
135,000 MILES • 2.4L • 4 CYL • 2WD • AUTOMATIC
URSULOROBLES
  • 47 POSTS
The vehicle is overheating. the temperature reaches over half of indicator, close to 3/4 in hot side of gauge and the cooling fan does not come on.
Nov 7, 2017 at 12:03 PM
  • 31,937 POSTS
Quick check; look at the cooling fan relay, swap it with another relay it is number 9 in the relay box, just make sure that it s a non essential circuit that you can isolate for a quick test drive, and it is the same configured relay.
Nov 7, 2017 at 5:33 PM
URSULOROBLES
  • 47 POSTS
I replaced the number 9 relay with a new one. I had the vehicle running for at least thirty minutes and the temperature went over half and no cooling fan came on. what else can I check?
Nov 8, 2017 at 4:55 AM
  • 31,937 POSTS
Check the power supply to the relay and trip it out and see if the fan actually comes on, you may have a faulty fan. i will go back and see where the sensor is that turns on the relay, i will re post soon.
Nov 8, 2017 at 6:12 AM
URSULOROBLES
  • 47 POSTS
Okay, thanks.
Nov 8, 2017 at 8:52 PM
  • 31,937 POSTS
there is a fan diode in the under hood relay box, and two sensors as per pic, i hope this helps as well.
Nov 10, 2017 at 7:33 PM
URSULOROBLES
  • 47 POSTS
The a/c pressure sensor sends correct reading (s) to the fuse in engine compartment to turn on the a/c cooling radiator fan . Where are the Ect sensor 1 and 2 located?
thanks,
Nov 13, 2017 at 12:56 AM
  • 31,937 POSTS
as pic says, one at bottom of radiator and one at rear of engine, i have no actual pic of the exact location, you should be able to see the wiring and locate the sensor that way.
Nov 13, 2017 at 5:25 AM
