After overhauling the engine, what could make the engine to mix water and oil in the engine sample? (after dipping the oil it looks milky)
Jan 11, 2018 at 2:00 AM
HARRY P
✓Experienced Mechanic
Cylinder head bolts may just need to be re-torqued, or maybe intake manifold bolts. If they were over tightened, then you will probably need new gaskets as well. Unfortunately, since it is not a US market car, I cannot look it up to see if anything else could be causing that.
