Code P1299, overheating, where is the coolant sensor located?
78,558 MILES • 1.2L • 4 CYL • 2WD • AUTOMATIC
MR.CURRIE0427
Hi to you, this may concern I'm having an overheating problem on my car listed above. I've been trying to locate the coolant sensor or a few days now, this is the code that popped up when i put the ob2 reader on (p1299).
Aug 26, 2022 at 3:47 AM
  • 110,246 POSTS
The code is related to what is called a cylinder head temperature sensor (CHTS). This is located at the center of the valve cover top, between cylinder 2 and 3 ignition coils.
I attached the directions below for replacing one. However, when the engine is cold, make sure the coolant level is full.
Let me know if that takes care of the problem.
Aug 26, 2022 at 6:36 AM
