Engine overheating
7,036,718 MILES • 1.5L • 4 CYL • 2WD • AUTOMATIC
THUSONKOE
My car recently overheated. the heater was not working 'no hot air coming out'. then the radiator cracked and was leaking and I replaced with a new one. I recently replaced a thermostat, and only discovered that the cooling fan is not responding.
please advise! thank you
Sep 11, 2016 at 10:09 PM
HMAC300
  • 48,601 POSTS
we have no information on this car, but what i am sending may be very similar to what you have. check all items in picture which are relays and fuses normally under-hood. this is from an Altima here in USA. it may be a bad CPU which will have to be scanned for codes.
Sep 11, 2016 at 11:34 PM
