Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Pontiac
Firebird
Engine
Symptoms
Overheat
Engine overheating
1996 PONTIAC FIREBIRD
66,000 MILES • 5.7L • V8 • 2WD • AUTOMATIC
MARCO HERRERA
MEMBER
1 POST
The test analyzer says to replace the cooling fan motor relay, but there are three, should I replace the three?
May 11, 2019 at 5:13 AM
Experienced Mechanic
Good afternoon,
What tells you to replace the relay?
https://www.2carpros.com/articles/how-an-electric-cooling-fan-works
What code did you see for this?
Does the cooling fan work at all?
I attached a wiring diagram for you to view. Test for power to the relay on the red wires first to be sure there is power available.
Images (Click to enlarge)
May 11, 2019 at 5:47 AM
🔧 Tools & Auto Repair Parts
Shop on Amazon →
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
