Engine Overheated/ Coolant Leak/ Vehicle Stalling?
216,000 MILES • 2.4L • 4 CYL • 2WD • AUTOMATIC
CMORALES5335
I want to be able to operate my car safely again. I replaced coolant and wanted to know if I have a bigger situation than a coolant refill. The front of the engine is shaking, and I think crankshaft is being affected because I had to push my vehicle over to a parking lot before work.
Sep 28, 2022 at 11:06 PM
  • 55,694 POSTS
The engine will shake if the idle speed is too low, or you have a misfire which causes the engine to stall at idle. But to be sure if you can upload a short video of the problem, I can see for sure what's going on so we can fix it.
Here are two guides to help us get started:
https://www.2carpros.com/articles/stall-at-idle
and
Please go over these guides and report back.
Sep 29, 2022 at 5:14 AM
