Engine overheat
300,000 MILES • 4 CYL • 2WD • MANUAL
BJJETRICH
Working properly: thermostat, radiator, pump.
Coolant seems to be blocked from circulating. What can I do?
Jul 27, 2017 at 5:16 AM
HMAC300
  • 48,601 POSTS
might be an air lock check radiator cap for being bad and then try running with hood on an incline with cap off pressure check system for an internal leak as well may be a blown head gasket.
Jul 28, 2017 at 12:37 AM
