Engine overheats at high speeds
85,000 MILES • 5.3L • V8 • 4WD • AUTOMATIC
HASSAN1110
The engine temperature is normal at the low speed but the engine overheated on higher speeds. No error at the system and no coolant leak.
Aug 5, 2018 at 2:03 AM
Good afternoon.
I assume you mean it is overheating?
Two things come to mind.
1. Thermostat. It may not be totally open.
2. Radiator clogged with debris not allowing circulation at higher rpm.
https://www.2carpros.com/articles/engine-overheating-or-running-hot
Aug 5, 2018 at 7:25 AM
