Engine overheats and heater only blowing cold air
130,000 MILES • 2.8L • 4 CYL • 2WD • AUTOMATIC
ROBERROSSIII
On Friday I shut my truck off. When out of town for the weekend. Monday morning when to start truck and notice thermostat was reading high right after I started ignition. Turned on the defroster, blowing cold air. Checked radiator it was cold and radiator hose had no pressure. Please help. Thank you
Mar 29, 2021 at 2:55 AM
  • 110,248 POSTS
It sounds low on coolant. When it's cold, check both the overflow reservoir and also the radiator itself for the coolant level.
https://www.2carpros.com/articles/engine-coolant-59420607
Let me know what you find.
Mar 30, 2021 at 12:15 PM
