Suddenly white smoke started coming from the engine. There is water in the coolant reservoir. There is no oil leaks. What could be the problem?
Sep 14, 2019 at 3:44 AM
SCGRANTURISMO
✓Experienced Mechanic
This is either going to be a blown head gasket or a crack in either the cylinder head or the engine block. Any time there is white smoke coming from the exhaust this is a sign that coolant is being burnt in the combustion chambers of your vehicle. Here is a link explaining what is going on below:
