engine or driveline problem
92,000 MILES • 3.9L • V6 • 2WD • MANUAL
BRYAN WELCH
  • 8 POSTS
When I take off in first gear my shifter moves to the right and it makes thump sound and it only happens in this gear and only when take off. Confused..
Please help.
Bryan
Apr 23, 2016 at 12:47 AM
HMAC300
  • 48,601 POSTS
check for broken motor mount on driver's side and transmission mount.
Apr 23, 2016 at 9:49 AM
BRYAN WELCH
  • 8 POSTS
I replaced the transmission mount and the motor mounts are good, so what else do you think it could be ?
Apr 23, 2016 at 11:42 AM
HMAC300
  • 48,601 POSTS
due to being a rear wheel drive it will always torque to the right, make sure the mounts are tight, if it thumps then it sure seems like a mount problem letting the engine go that way. check for something broken as well. or not centered on mounts.
Apr 24, 2016 at 1:13 AM
BRYAN WELCH
  • 8 POSTS
What is the easiest way to check to see if the drivers side motor mount is bad?
Apr 24, 2016 at 9:19 PM
HMAC300
  • 48,601 POSTS
if it is an automatic brake torque it and if the engine jumps replace the mount being a manual, see if you can jack up that side of motor and see if mount separates.
Apr 24, 2016 at 11:47 PM
BRYAN WELCH
  • 8 POSTS
I put my floor jack under the oil pan and neither side lifted,in fact the truck started to lift up.
Still confused.
Am I checking right or could it be something else ?
Apr 25, 2016 at 12:54 PM
BRYAN WELCH
  • 8 POSTS
Someone told me today that it could be my upper or lower control arm bushings, but if that was the case wouldn't my steering be pulling to one side or other, which it does not. What do you think?
Apr 25, 2016 at 2:19 PM
HMAC300
  • 48,601 POSTS
Yes it may be a control arm bushing . it would not pull left or righ,t but would wear a tire out have the front end checked as it may be a ball joint as well.
Apr 25, 2016 at 10:43 PM
BRYAN WELCH
  • 8 POSTS
I did inspect the control arm bushings, but I will have the front end inspected by a professional and I will get back with you.
Apr 25, 2016 at 11:31 PM
  • 55,710 POSTS
Looking forward to your response, It sure sound like the engine mount though, a classic problem
Apr 26, 2016 at 1:30 AM
BRYAN WELCH
  • 8 POSTS
Thank you for helping me through this problem and I cannot have my front end checked until Friday when I get paid. I will contact you on Friday.
Apr 26, 2016 at 3:37 PM
