Engine only fires on front 2 pistons
1974 LAND ROVER SERIES 3
2.6L • 5 CYL • AWD • MANUAL
LUDIMOUTON
Hi
I am based in South Africa. My Land Rover series 3, straight 6 petrol, 2.6, R6, is only firing on it's 2 front pistons.
All 6 spark plugs are brand new and in working condition and all 6 are sparking. I have fitted a new distributor cap. The rings are fine and have compression. The valves work on a crank system. The vehicle starts and idols.
I've tried everything by now and contacted almost everyone. I need to get it fixed asap, as I have to put it through the roadworthy test. Any help will be appreciated hugely.
Regards
Ludi Mouton
Feb 27, 2015 at 5:19 PM
WRENCHTECH
  • 20,761 POSTS
How do you know it's only firing on 2 cylinders? The engine cannot run on only 2 out of 6 cylinders.
Feb 27, 2015 at 9:10 PM
LUDIMOUTON
When the engine idols and I unplug the spark plugs one by one, the engine only starts to die when I unplug the 2 front plugs. When I remove the other 4 further backwards, the engine keeps running.
Feb 28, 2015 at 11:08 PM
WRENCHTECH
  • 20,761 POSTS
As I stated, the engine cannot run on only 2 cylinders. That's not to say there aren't issues with the other cylinders but they are not completely dead. You need to start with compression tests and any other testing that will determine what is going on with those other cylinders such as injector balance and spark testing..
Feb 28, 2015 at 11:12 PM
LUDIMOUTON
I attached a video of me removing the spark plugs, while the engine idols. Everyone I've contacted are just as perplexed.
Mar 1, 2015 at 2:14 PM
