Oil Pressure Sensor location needed on the vehicle listed above?
Thanks
Dec 14, 2022 at 3:57 PM
✓Experienced Mechanic
The oil pressure sender is located right above the starter motor. Here is a diagram in the images below. Check out the images (below). Please let us know if you need anything else to get the problem fixed.
