Engine oil pressure sender
120,000 MILES
STEVIE12
  • 55 POSTS
Low oil level was on for two days. it is off checked oil dip stick it full the low oil level light went off, but now check engine light is on.
Apr 11, 2017 at 10:18 AM
CARADIODOC
  • 34,414 POSTS
The place to start is by having the diagnostic fault codes read and recorded. Those will indicate the circuit or system that needs further diagnosis, or the unacceptable operating condition. The people at many auto parts stores will read those codes for you for free.
Apr 11, 2017 at 10:24 AM
STEVIE12
  • 55 POSTS
Thanks.
Apr 11, 2017 at 10:33 AM
  • 55,721 POSTS
It sounds like the level sensor has gone bad this will light the check engine light.
Best, Ken
Apr 15, 2017 at 5:15 AM
STEVIE12
  • 55 POSTS
Check engine light on code p0011
Apr 15, 2017 at 6:00 AM
CARADIODOC
  • 34,414 POSTS
P0011 - Camshaft position sensor performance.
You didn't list your engine size. The diagnostic procedure varies according to which engine you have.
Apr 15, 2017 at 4:24 PM
STEVIE12
  • 55 POSTS
3.5
Apr 15, 2017 at 8:43 PM
  • 55,721 POSTS
This code can also be set by low oil pressure. I would do a manual check on the engine to see if the pressure is low, if so you will need to pull the pan and check the oil pump pick up for blockage due to lack of maintenance.
But I would try a new oil pressure sender, at the time install a manual oil pressure gauge which you can get from amazon for $35.00
https://www.amazon.com/gp/product/B0186NTKP8/ref=as_li_qf_sp_asin_il_tl?ie=UTF8&tag=2carprcom-20&camp=1789&creative=9325&linkCode=as2&creativeASIN=B0186NTKP8&linkId=4339f7aba2cec02e6e42c22dd30f47c7
Please run this test and get back to us so we can continue helping you.
Best, Ken
Apr 17, 2017 at 7:04 AM
STEVIE12
  • 55 POSTS
Thanks a mechanic told me I need a engine oil pressure sender did check oil dip stick full don't understand why check engine light is on
Apr 17, 2017 at 7:15 AM
  • 55,721 POSTS
Yep that where I would start. here is its location so you can replace it.
First jack up the car
https://www.2carpros.com/articles/jack-up-and-lift-your-car-safely
here are some diagram that will help you.
Best, Ken
Apr 17, 2017 at 8:07 AM
STEVIE12
  • 55 POSTS
Thanks Ken
Apr 17, 2017 at 8:26 AM
