Engine oil pan removal
2010 CHEVROLET COBALT
181,000 MILES • 2.2L • 4 CYL • 2WD • AUTOMATIC
DUWHOP31
  • 153 POSTS
How do your remove and replace an oil pan on the car listed above? Can you remove all the bolts and just pull it off?
Jul 3, 2019 at 12:27 PM
Hi Duwhop31,
Here is the process for removing and installing the pan. Let me know if you need anything else. Thanks
Jul 3, 2019 at 12:46 PM
DUWHOP31
  • 153 POSTS
So you only have to take off the drive belt besides taking off the bolts of the oil pan?
Jul 3, 2019 at 3:19 PM
It also says the lower AC compressor bolt but I think this is just for clearance so I would play that by hear. Other than that, it looks like that is it according to the service manual.
Jul 4, 2019 at 12:42 PM
