Engine oil level was dropping suddenly and mixing with coolant in the cooling system due to which car went into overheat. Flushed clean the cooling system and changed the gas kit on the engine cooler. Problem subdued for a while and reoccurred again.
Parked car for a month and appears the mixture of oil and water has entered engine.
Engine has not seized yet. Kindly advice how to identify the problem and cause and how to solve it.
With much anticipation,
Regards,
Osman.
Regards,
Osman.
Aug 27, 2018 at 3:01 AM
