Engine oil consumption?
120,000 MILES • 1.4L • 4 CYL • 2WD • MANUAL
WAELDEGHLI
Is it normal to consume one liter of engine oil for 1,000 km?
Mar 25, 2024 at 4:10 AM
  • 55,721 POSTS
No, this is not normal, 1,000 is about 621 miles, so it sounds like something is wrong like you have a broken oil control piston ring. I would remove the spark plugs for inspection to see which cylinder is having the issue, this guide can help:
https://www.2carpros.com/articles/how-to-change-spark-plugs
Also, it could be the valve stem seals or the PCV system. Here is the location of the PCV so you can change it out which is what I would do as well because this is a normal service item. Also, can I ask if the engine is burning oil? Please go over this guide:
https://www.2carpros.com/articles/blue-smoke-from-engines-exhaust
Spark Plugs
Type
NGK .................... BKR5ES-11
CHAMPION .................... RC10YC4
Check out the images (below). Please upload pictures or videos in your response to the problem so we can see what's going on.
Mar 26, 2024 at 2:47 AM
WAELDEGHLI
Thanks a lot sir. When i draw up the oil level stick and the engine is running there is air blowing from inside. Is that mean anything about the problem?
Mar 26, 2024 at 9:34 PM
  • 55,721 POSTS
Up, this means there is excessive crankcase pressure and there is a problem from inside the engine like a broken piston or bad rings. The engine will need to be disassembled to see what happened.
Mar 27, 2024 at 2:20 AM
  • 55,721 POSTS
anything?
May 11, 2024 at 5:55 AM
