Engine oil change
150,000 MILES • 3.5L • 6 CYL • 4WD • AUTOMATIC
TAYODAISI
  • 8 POSTS
I had the oil changed after two and half months, but noticed the car vibrates each time i start up the engine and later subsides. But reoccurs on each start up of the engine. I was wondering what could be the cause?
Aug 30, 2017 at 12:32 AM
HARRY P
  • 2,292 POSTS
Have you had the truck tuned up ever? I would say that at 150,000 miles it is probably time for spark plugs, wires, PCV valve, air filter, and other such maintenance items.
They can each cause the symptoms that you are describing.
Aug 30, 2017 at 2:04 AM
TAYODAISI
  • 8 POSTS
Thanks a lot, i will do just that to start with. I appreciate it.
Aug 30, 2017 at 3:21 AM
