How often do I need to replaced the Oil and Filter
80,000 MILES • 2.5L • 4 CYL • 4WD • AUTOMATIC
MANUELGARCIA
How often must be replaced the oil and filter? What type of oil should I use? Blend Synthetic or Fully Synthetic? How often must be replaced the ATF Automatic Transmission Fluid? Note: I would appreciate it the right answers for my car. Thank you very much for your desire answer these questions. The Lord bless you.
Oct 5, 2016 at 2:34 AM
HMAC300
  • 48,601 POSTS
recommended service changes are in your owners manual.synthetic oil is best and semi synthetic is 25% synthetic oil. synthetic can use longer oil changes like 10,000 miles if you switch to synthetic there will be some oil usage at start. information i am sending is also in your owners manual.
Oct 5, 2016 at 5:26 AM
