Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Mercedes Benz
C300
Engine
Oil
Type
Engine oil weight
2009 MERCEDES BENZ C300
153,000 MILES • 3.0L • 6 CYL • 2WD • AUTOMATIC
HARDY L STATEN
MEMBER
1 POST
What weight oil should I use?
May 1, 2020 at 12:33 AM
DANNY L
Experienced Mechanic
Hello, I'm Danny.
I have attached the information you requested below.The weight oil to use is determined by the climate in your area,see below.Hope this helps and thanks for using 2CarPros.
Images (Click to enlarge)
May 1, 2020 at 2:23 AM
Add image or video
Ask a new question
Engine won't start
Headlight — Not Working
