Engine oil
98,000 MILES • 3.2L • V6 • AUTOMATIC
RAJIVCH
I believe the service center has put 8 liters of engine oil in my car at the time of oil change, is it safe for the car and to drive or I need to take any remedial action
Apr 7, 2016 at 4:32 PM
HMAC300
  • 48,601 POSTS
check oil level first if way above fill mark then try to remove about a quart it takes 6.3L so that should get you close enough to drive to have them correct it. if just a tad above fill mark then drive it there.
Apr 8, 2016 at 12:12 AM
