engine oil capacity
178 MILES • 5.4L • V8 • 4WD • AUTOMATIC
DIMITAR STEFANOV GLAVINOV
  • 28 POSTS
How many liters of engine oil can fit the engine ?
May 21, 2021 at 3:31 PM
This engine requires 6.6L (7 quarts) if you are changing the oil and filter.
Here is a guide that will help with this if you need it:
https://www.2carpros.com/articles/how-to-change-engine-oil-and-filter
Below is the full document from the manual that includes part numbers if you need that as well.
Let us know if you have other questions. Thanks
May 22, 2021 at 11:03 AM
