Engine shuts off when transmission is shift into drive?
289,066 MILES • V6 • 2WD • AUTOMATIC
BLESSING EWOBOR
  • 753 POSTS
Good day,
The engine of the vehicle will shut down sometimes when the transmission gear lever is shifted to drive or reverse. I thought the problem could be a clog valve body, I replaced the valve body, but it didn't solve the people. The idle speed of the engine is up to 1.5k RPMs. What could be the problem?
Oct 8, 2022 at 9:40 AM
  • 110,251 POSTS
It could be related to the torque converter. That is what allows the engine to remain running when the vehicle is stopped.
Have you checked to see if there are diagnostic trouble codes stored in the system? On this vehicle, I would recommend having the can-bus scanned. CAN stands for controller area network.
Basically, all the computers/modules are tied together via a few wires. This type of scan will retrieve codes regardless of the module storing them.
Here is a link that explains how it is done:
Let me know. Also, let me know if it jumps when this happens as if you popped the clutch on a vehicle having a manual transmission.
Oct 8, 2022 at 3:24 PM
BLESSING EWOBOR
  • 753 POSTS
I scanned the vehicle, there are no codes in its memory.
Oct 9, 2022 at 1:40 AM
  • 110,251 POSTS
If it stalls, does the vehicle lurch or does it do anything out of the ordinary other than stall? Also, are the engine RPMs low when it happens? Have you ever noticed a rough idle?
I'm asking because if there was an issue with the torque converter or transmission, it should have set a code.
Oct 9, 2022 at 1:12 PM
BLESSING EWOBOR
  • 753 POSTS
The engine works perfectly, the RPMs gets reduced graduation until the engine shuts down when the transmission is placed in reverse or drive.
Oct 9, 2022 at 3:02 PM
  • 110,251 POSTS
If the RPMs slowly reduce, will the vehicle move when it is happening? If it does, that sounds more engine related and not transmission. If you would have told me it would lurch and stall, then I would think it was the torque converter.
Does it respond the same way all the time? I'm sorry for so many questions. I'm just trying to get a clear understanding.
Oct 10, 2022 at 11:39 AM
BLESSING EWOBOR
  • 753 POSTS
The vehicle will not move, it will shake suddenly and tripped off.
Oct 10, 2022 at 12:18 PM
  • 110,251 POSTS
If it is neutral, are you able to rev the engine normally? If so, I suspect something is failing in the torque converter.
Oct 11, 2022 at 11:04 AM
BLESSING EWOBOR
  • 753 POSTS
Good morning,
At neutral, the engine revs normally.
Oct 11, 2022 at 6:03 PM
  • 110,251 POSTS
Based on your description, my first suspicion is with the transmission and not the engine. If I was to start checking, I would start with the torque converter clutch assembly. I need to confirm something. You identified the vehicle as an RX300. I'm only showing an RX350 in the manuals. Could you confirm the model for me?
Oct 12, 2022 at 10:34 AM
BLESSING EWOBOR
  • 753 POSTS
Good evening, the vehicle is not working fine after replacing the torque converter.
Oct 15, 2022 at 9:08 AM
  • 110,251 POSTS
Is this an RX350? Also, the converter itself may not be the problem. It could deal with a line pressure issue, the TCC, and so on.
I need confirmation of the model. If it is an RX300, I have no info on it, and I'll have to go about testing differently.
Oct 15, 2022 at 2:48 PM
BLESSING EWOBOR
  • 753 POSTS
Good evening sir,
It is RX350, if the problem is the TCC, could there be any solution without replacing the torque converter?
Could I have the values or readings for the line pressure?
Thank you very much for your concern so far.
Oct 18, 2022 at 6:25 AM
  • 110,251 POSTS
The converter would need to be replaced.
There are two different transmissions for this vehicle. I attached the directions for testing line pressure below.
The first 7 pics are for the U660E transmission, and the remaining are for the U660F.
I hope this helps.
Oct 19, 2022 at 10:42 AM
BLESSING EWOBOR
  • 753 POSTS
Good morning, sir,
Thank you sir.
Oct 19, 2022 at 1:34 PM
  • 110,251 POSTS
As always, you are very welcome. If you have a chance, let me know how things turn out for you and what is found.
Oct 20, 2022 at 10:56 AM
BLESSING EWOBOR
  • 753 POSTS
Good morning sir,
I will, thank you
Oct 20, 2022 at 12:07 PM
BLESSING EWOBOR
  • 753 POSTS
Good evening sir,
sir, concerning the test result of the one of the images sent (last image).
1. "D position circuit fluid leak" does it mean the circuit leak in the valve body or the transmission?
2. "clutch no. 1 (C1) defective"
does it mean that there is hole in the clutch or burnt clutch plate to have low pressure?
Oct 21, 2022 at 9:20 AM
  • 110,251 POSTS
The leak would likely be internal (valve body). As far as the clutch being defective, that could indicate a few things. Something could be preventing it from engaging, clutches have failed, but I don't think a hole is likely.
Oct 21, 2022 at 2:17 PM
