Engine nurzle not responding
200,000 MILES • 3.3L • 6 CYL • 2WD • AUTOMATIC
OLUDARE
1st fuel norzule not working! Tested when remove the plug responding at all, we ve because of that replaced the 2 cylinder, change flywheel, nurzle tested independently working but when plugged not responding to engine performance!
can a weak crankshaft sensor or ignition coil responsible for this?
Dec 28, 2020 at 6:03 PM
A weak crank signal would not cause this. We need to start with checking for codes as if you have an injector that is not firing then I suspect we have codes that will point us in the correct direction.
This could be a control module or a wiring issue but did you test the injector as shown in the guide below?
https://www.2carpros.com/articles/how-to-test-a-fuel-injector
Let's start with checking for codes and we can go from there. Thanks
Dec 29, 2020 at 7:56 AM
OLUDARE
My mechanic has just scanned the car now, these are the results:
Injector circuit open - cylinder 1
Leak detect pump solenoid circuit
02 censor circuit - no activity detected - bank 1 sensor 2
Manifold absolute pressure/ barometric pressure circuit: high
Dec 30, 2020 at 5:53 PM
Sounds like we have some wiring issues assuming all these are related. However, did they give you the actual codes so I can look them up? Unfortunately they don't list the codes by description. Thanks
Dec 31, 2020 at 10:49 AM
