Engine not starting no current to spark plugs, where is the ECM relay located?
275,000 MILES • 1.5L • 4 CYL • 2WD • AUTOMATIC
ROLAND KHAN
engine cranking but not starting. I would like to know the location of the ECM relay and color.
Jan 4, 2024 at 6:50 AM
  • 55,694 POSTS
Sure, here is the location of the PCM relay and I have included a guide to help test it if needed.
Check out the images (below). Let us know if you need anything else.
Jan 5, 2024 at 1:57 AM
ROLAND KHAN
my IPDM has only 4 relays and fuses.
Jan 28, 2024 at 5:23 AM
  • 55,694 POSTS
Hmm, can you please upload an image of it?
Jan 29, 2024 at 1:48 AM
