Engine not starting
26,231 MILES • 1.1L • 4 CYL • 2WD • MANUAL
MENZI
Hi, my car is not starting, it swings and swinging, but not run the engine.sometimes the engine runs for few minutes and off are again.it It's cut off the fuel pump but when it's about to run the engine you here the sound of a pump come then it's start for a few minutes.
Oct 25, 2019 at 2:41 AM
  • 110,248 POSTS
Welcome to 2CarPros.
It sounds like you have a bad fuel pump or fuel pump relay. I don't have technical information on this vehicle because it isn't offered in the US, but the relay should be in the main power distribution box under the hood. Switch it with another relay having the same part number to see if it makes a difference.
If you want to test that specific relay, here is a link that explains how it is done:
Here are a few links you may find helpful:
Let me know what you find.
Oct 25, 2019 at 11:35 AM
