Engine not starting
158,000 MILES • 2WD • AUTOMATIC
TOLUADE27
All indicators light not coming on except door indicator on the mileage board and engine not starting ever since. This started after I replaced the engine fan relay. Please help.
Nov 13, 2017 at 3:38 AM
  • 110,248 POSTS
If relay replacement is when it started, I would suspect a short which most likely took out one of the main fuses under the hood. Check all main fuses. If you find one that is bad, remove the relay prior to replacing it to see if things are back to normal. If they are, there must be a short in the fan system.
Nov 13, 2017 at 9:55 AM
