Engine not starting
2,012 MILES • 1.2L • 3 CYL • 2WD • AUTOMATIC
WUBSHET WORKNEH
  • 6 POSTS
After rebuilding the engine, on the gauge there is a light is blinking when the key is on and cranking. i checked so many things like; camshaft position sensor, pulley sensor, spark plug ignition coil, all the electric line and fuse are checked. but the red light is blinking on the gauge. how can i start the engine and solve the light?
Nov 11, 2020 at 6:13 PM
  • 110,248 POSTS
I'm not sure which model you have, but can you identify what light (red) is flashing? Also, if possible, can you record what is happening so I can both hear the engine cranking and see what it's doing?
Here is a link that explains things to check with a crank no start condition. Take a look through it and see if it helps in any way.
Nov 12, 2020 at 7:23 AM
WUBSHET WORKNEH
  • 6 POSTS
2012,k6A, every wagon.
Nov 12, 2020 at 11:09 PM
  • 110,248 POSTS
That model isn't offered in the US, so my technical info is very limited. However, I'll try to help.
The red light that blinks, is it a security indicator? Does the vehicle have an anti-theft system? If so, is it an original equipment product or something that was added?
Nov 13, 2020 at 11:34 AM
