Cranks does not start
PKUMAR
  • 2005 HYUNDAI ACCENT
  • 1.5L
  • 3 CYL
  • TURBO
  • MANUAL
  • 135,000 MILES
Car listed above is the CRDI 2005 model. Cranking is good, battery almost new and not any error in scanner. But engine not start in cold or hot position. Starter repaired by good electrician again pushing vehicle by 2-3 men start engine easily, smooth running and good pickup, so please help me for problem.
Friday, September 27th, 2019 AT 4:08 AM
If the engine starts with no issue by popping the clutch then we have to suspect the starter or starting system. The fact that the starter was rebuilt let's assume for now that this is okay. Can you get a video of the engine cranking and what that sounds like? I am wondering if the starter is not engaging the flywheel properly so it is not actually spinning the engine.
Let me know and we can go from there. Thanks
https://www.2carpros.com/articles/how-a-starter-and-solenoid-works
Saturday, September 28th, 2019 AT 8:06 AM
