Engine in limp mode?
120,000 MILES • 1.3L • 4 CYL • 2WD • MANUAL
MICKEY MOO
The throttle body and electronic foot pedal was replaced. car starts and runs well, except very slow as if it's on limp mode.
Nov 27, 2020 at 8:47 PM
  • 55,684 POSTS
It sounds like the throttle body needs to be relearned which is common if you do not service the throttle bore correctly. This guide will help you with the CAN video below which will show you how you can relearn the throttle bore:
and
https://youtu.be/InIlnsjOVFA
and
Nov 29, 2020 at 1:32 AM
