no electric current going through to the engine
1 MILES • 1.6L • 4 CYL • 2WD • MANUAL
VINAH1
Basically in short, there is no electric current going through to the engine. I have scanned it and there are no codes or any data appearing.
Also, just to add on to that. I have had to change the distributor four times because every time i change it, it lasts for a maximum of three minutes then it goes out and there is no current again and so I am scared to change it again. Any help is very much appreciated please.
Aug 18, 2017 at 5:10 AM
  • 55,711 POSTS
It sounds like you have a ground cable that is not connected, can you check to see if there is a ground strap or cable from the frame to the engine?
Please let us know what you find.
Cheers, Ken
Mar 11, 2021 at 10:46 AM
VINAH1
Hi Ken,
Thanks for response, i have checked the cable, and there is a ground cable connected, so i have attached another cable but to no avail..
  • 55,711 POSTS
Okay, the next place I would check is the ignition switch, Here is a guide and a diagram (below) so you get check it out and get back to me.
Cheers, Ken
