Engine not getting comprssion
180,000 MILES • 2.2L • 4 CYL • FWD • AUTOMATIC
JASONW7684
  • 5 POSTS
The engine turns over but there is no compression as if timing is out but I have replaced the timing chain tensor gears and replaced cam sensor. I am stumped as what to look at next.
Mar 21, 2017 at 12:47 PM
HMAC300
  • 48,601 POSTS
check timing chain for being aligned properly if overhead cam you bent valves if not then still sounds out of time.
Mar 22, 2017 at 12:50 AM
