Some mornings after car has sat it will not crank over right off. After several cycles of turning key on and off it will fire right up. Does it mainly when outside temperature is not real hot. I just put new battery in last night. All lights on dash and headlights, radio work while not cranking. All at once it will fire up and work rest of day. Until it sits up
Does not do it 100% of the time. When problem occurs it always eventually cranks up.
Nov 4, 2018 at 1:19 AM
