Engine not cranking
77,800 MILES • 7.5L • V8 • 2WD • AUTOMATIC
RCHAMPION1958
  • 7 POSTS
Joe, hi I'm working on a 1990 Ford Econoline RV, there is no power going to either of the pumps (low pressure in tank and high pressure on frame). I ran power from the battery to both pumps and both are working, the engine will crank when I put a little bit of ether but will not stay running. It's not getting fuel to the fuel injection. Is there a pressure regulator? I want to crank the engine and make sure it's not knocking or overheating before we spend any big money getting the electrical repaired. Thanks and no problem starting new thread, didn't know.
Apr 21, 2020 at 12:02 PM
  • 110,248 POSTS
No problem whatsoever. I'm glad I got to it before someone else. LOL
The fuel pressure regulator is on the fuel rail. I attached a picture of its location. Also, there is a fuel pump cut off relay under the dash, left side. The fuel pump relay is under hood on the right side inner fender. See picture 2
Let me know if that's what you needed or if you have other questions.
Apr 21, 2020 at 12:17 PM
RCHAMPION1958
  • 7 POSTS
You said there was a fuel pump cutoff relay under dash left side, what would I be looking for?
Apr 21, 2020 at 12:22 PM
  • 110,248 POSTS
Is this a 250 or 350? As far as the relay, I have no pics because of the model year. However, the manual is only indicating under he left side of the dash. I am looking at an E350.
If you look at picture 1 below, that is the under dash fuse panel. Fuse 18 is for the fuel pump. Since the relay isn't in that panel, it is likely a separate relay. Chances are it is hanging. LOL
Apr 21, 2020 at 12:55 PM
RCHAMPION1958
  • 7 POSTS
Thanks Joe, was looking on line and found picture of it. Checked all the fuses and those are good. Will try pressure regulator first, both pumps are working (wired straight) but won't run after starting fluid burns off. Not spraying but a little, don't want to blow the heads off of it! Will let you know what I find. Thanks
Apr 21, 2020 at 1:24 PM
  • 110,248 POSTS
If I understand correctly, with the pumps hot wired and running, it stalls when the starting fluid burn off, correct? Are the pumps producing pressure? Have you checked for an injector pulse?
https://www.2carpros.com/articles/how-to-test-a-fuel-injector
Apr 21, 2020 at 1:34 PM
RCHAMPION1958
  • 7 POSTS
Morning, I tested for power at the injectors (none) and the next thing was to check and see if there was power going to the EEC at the power distribution box. This van has no PDB! It didn't say what to check if there was no PDB. Stopped right there. There are 2 relays on the passenger side engine compartment and EEC test Port. Not sure what I should do. Mechanical repairs yes, just not trained on electrical!
Apr 23, 2020 at 12:02 AM
  • 110,248 POSTS
Pull the EEC relay and switch it with a different one having the same part number. Or, here is a link showing how to test one:
Let me know if that changes things. The EEC relay can shut everything down.
Apr 23, 2020 at 10:52 AM
RCHAMPION1958
  • 7 POSTS
Sir, I want to thank you for all of your assistance in helping me with this electrical problem. With all your expert advice, diagrams and links to help me understand relays and their functions the engine is now running! How much do I owe you? Your help has been priceless!
Apr 25, 2020 at 12:42 AM
  • 110,248 POSTS
You are very welcome. Let us know if you need anything in the future.
Apr 25, 2020 at 3:38 PM
