After replacing the oil pressure sensor the engine has a ticking noise and idles rough
215,155 MILES • 5.3L • V8 • 2WD
WILLIE HENSON
My oil pressure sensor went out so I removed the intake and changed it. after putting everything back together I started the vehicle and now it Idles rough and I have a ticking noise coming from my engine. Also a new code p0307 it has a misfire in 7. I took it back apart and cleaned my injector it’s running rough. any ideas what I could do next?
Feb 20, 2021 at 8:38 AM
  • 110,246 POSTS
Since you had it apart and not it's running rough, the first thing I would be checking for is an engine vacuum leak. It's possible a vacuum hose was left off or damaged.
Here is a link that shows how to find a leak:
Let me know what you find. Also, let me know if the misfire is gone or if there are any new codes.
Take care and God Bless,
Feb 21, 2021 at 8:56 AM
WILLIE HENSON
So I have fixed the problem it ended up being a misfire on all 8 cylinders and my fuel injectors was still dirty, but now I’m just left with a tick that came from nowhere. any ideas what that could be? I started driving it and the tick stops after I hit the speed limit but starts back up when I come to a stop again.
Feb 21, 2021 at 9:11 AM
  • 110,246 POSTS
If possible, record what you hear and upload it for me to hear. Hopefully, I'll be able to identify it.
I will watch for your reply.
Feb 21, 2021 at 10:35 AM
WILLIE HENSON
This is what I have:
Feb 21, 2021 at 10:43 AM
WILLIE HENSON
As you can hear from the video the tick stops once I get so far up on the RPMs then comes back as the RPMs goes back down.
Feb 21, 2021 at 10:45 AM
  • 110,246 POSTS
I hear it. Do me a favor. Take a long-handled screwdriver or even a piece of 2x4 and place it on one valve cover at a time to see if you can tell which side it is coming from. I am thinking it is a loose rocker arm.
I know you replaced the oil pressure sensor. Was there ever a point the engine didn't have oil pressure?
Feb 21, 2021 at 11:12 AM
