whooshing sound
140 MILES • 2.1L • 4 CYL • 2WD • AUTOMATIC
BINGBO
engine makes loud whooshing sound when starting cold. getting worse, like air escaping or pressure leak somewhere. only lasts for seconds. been doing this for 6 months.
Feb 27, 2016 at 8:25 AM
HMAC300
  • 48,601 POSTS
It sounds like you may have a vacuum leak or a serpentine belt that is dry. Here is a guide to help check for the vacuum leak and to change the belts.
and
https://www.2carpros.com/diagrams/toyota/pickup/1991
Feb 28, 2016 at 12:08 AM
TOYOTA1985
Noises problem
1985 Toyota Pickup 4 cyl Two Wheel Drive Manual
I have a rattle in the engine at higher speeds especially when i accelerate at higher speeds. what could be the problem/problems
thanks for your time
Beth
Feb 5, 2019 at 4:42 AM (Merged)
  • 31,937 POSTS
Hi there,
If you can post your engine type, i will be able to have a better idea as to what your problem may be. But i would be checking engine oil pressure first, do this with a master gauge. if the oil pressure is ok, start looking at external items as well, alt, water pump etc.
Mark (mhpautos)
