When driving there is a loud knocking noise
160,000 MILES • 2.2L • 4 CYL
LESLIE KEITH JAMERSON
a loud knocking sound inside the engine when driving.
Jul 15, 2021 at 3:59 AM
Good afternoon,
If it is coming from inside the engine, something internal has failed like a bearing or broken piston.
https://www.2carpros.com/articles/engine-noises
It would be cheaper to replace the engine with a used engine that tries to fix the issue.
If you could attach a video of the noise, we can confirm it.
Jul 15, 2021 at 4:35 AM
SQM
  • 6,383 POSTS
First thing you should do is check your oil level. Low oil could make noise from the engine.
This article might be helpful:
https://youtu.be/OTeg2CUB5NE
I have attached a step by step diagnosis procedure.
Let me know if you have any questions.
Jul 15, 2021 at 4:39 AM
thank you.
Jul 15, 2021 at 10:17 AM
You are welcome.
Keep us updated.
Jul 15, 2021 at 10:57 AM
