Engine no start after warm, always tough to start?
189,000 MILES • 4.0L • 6 CYL • 2WD • AUTOMATIC
BRENT BRANDON RIOS
Mostly the engine has difficulty starting. The engine won't stay running more than a minute or two. Then after warm engine the engine repeatedly shuts off. Very low power if I put truck in gear.
May 21, 2023 at 11:12 PM
  • 55,746 POSTS
The first thing we should do is check for a vacuum leak.
This guide use when the engine is cold only:
This guide can help as well:
https://www.2carpros.com/articles/stall-at-idle
Also, we should run the codes because you may have a bad MAF sensor.
Please go over these guides and get back to us.
May 22, 2023 at 8:06 AM
