Engine cranks no start after replacing battery
200,000 MILES • 2.5L • 4 CYL • 2WD • AUTOMATIC
FRANKIE LEGARDA
Changed battery with new one, tried to start wipers and flashers and lights on and car won't start. it cranks but won't start.
Jan 18, 2020 at 2:39 AM
  • 110,248 POSTS
Was this the issue before replacing the battery? Let me know.
Take a look through this link to see if anything helps. It covers the most common causes of a crank no start.
Let me know. I will watch for your reply.
Jan 18, 2020 at 10:09 AM
FRANKIE LEGARDA
We jumped the old battery and it started after 2 days we jumped it again and that's when the issues started.
Jan 18, 2020 at 3:05 PM
  • 110,248 POSTS
Have you replaced the battery? When trying to start it, does it sound normal and turning fast enough to start? If it is, then we have to check if it is getting fuel and spark to the engine. Here are a couple links explaining how that is done:
The easiest thing to do is see if it starts for a couple seconds with starting fluid. If it does, then we know it is a fuel related issue. If it doesn't, then suspect it is an ignition spark related issue.
Let me know. Also, try the starting fluid trick and let me know the results.
Jan 19, 2020 at 5:15 AM
