Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Daihatsu
Terios
Engine
Symptoms
Runs Rough
Engine needs to be thoroughly heated before running smoothly
2005 DAIHATSU TERIOS
150 MILES
TCI SIXTO
MEMBER
1 POST
The engine starts fine, but shuts off when you shift to reverse or drive. It needs at least thirty minutes idling before it runs properly.
May 1, 2019 at 6:21 AM
Experienced Mechanic
This sounds like it could be a vacuum leak or the engine coolant sensor has gone bad here are two guides to help walk you through the repairs.
and
https://www.2carpros.com/articles/coolant-temperature-sensor-cts-replacement
May 2, 2019 at 7:29 AM
Add image or video
Ask a new question
Engine won't start
