Engine needs to be thoroughly heated before running smoothly
150 MILES
TCI SIXTO
The engine starts fine, but shuts off when you shift to reverse or drive. It needs at least thirty minutes idling before it runs properly.
May 1, 2019 at 6:21 AM
  • 55,743 POSTS
This sounds like it could be a vacuum leak or the engine coolant sensor has gone bad here are two guides to help walk you through the repairs.
and
https://www.2carpros.com/articles/coolant-temperature-sensor-cts-replacement
May 2, 2019 at 7:29 AM
