Engine mounts
179,000 MILES • 3.0L • V6 • FWD • AUTOMATIC
DAVION FARLEY
I recently replaced two engine mounts in my car, the other two looked fine and the engine still jumps a little when accelerating to ten miles per hour then stops. it is one quick jump and it is fine for the rest of the drive until i have to use reverse or park.
Sep 27, 2016 at 5:12 PM
HMAC300
  • 48,601 POSTS
recheck the ones that you did not replace and make sure others bolts are tight.
Sep 28, 2016 at 12:10 AM
